Permabanned
- 26 Oct 2002
ernysmuntz said:Rubbish no they won't!!!!
Unless your drive specifically supports SATA II & I...
In which case its not a "SATA II" drive, its a drive that supports SATA I & II....Do all SATA II drives support SATA I?
My drives will work on SATAI but to get that to work, you need to use a utility to set them at that, and unless you got a SATAII based chipset your stuffed...
To ensure seamless backward compatibility between SATA 1.5 Gbit/s controllers and SATA 3.0 Gbit/s devices, the latter devices are required to support the original 1.5 Gbit/s rate. In practice, some older SATA controllers do not support SATA speed negotiation, and require that SATA 3.0 Gbit/s peripherals be manually hardlimited to 1.5 Gbit/s with the use of a jumper.
