Hi - maybe someone can help
My brother's PC like mine had become unstable after the upgrade from Win 7 so I went to do a clean install
Mobo Z97-K Intel Z97 (Socket 1150) DDR3 ATX Motherboard
SSD SM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive
I wanted to boot from USB2 stick to run Parted Magic to secure erase drive. Despite setting USB as 1st boot device and clicking on drive in Secure boot menu it constantly booted into windows.
I had previously used same USB stick to clean install on my PC with standard Samsung SSD so I know it works.
The stick was in both a usb2 port and a USB3.
I even tried the recovery boot in Windows where the USB drive also showed up but clicking on it still booted to Windows.
I ended up resetting the PC. [I don't know if this is as good as a clean install]
Is this a BIOS fault or peculiar to M2 drives. If the later then how to secure erase it! [option in Samsung magician not available to secure erase & their created USB never works as SSD drives are "frozen" so hence using Parted Magic]
Any thoughts or tips welcome
