Is there anyway when using Explorer in windows you can make it act like XP/Vista.
Whilst I can transverse using the right panel, it does not open up the relevant location on the left panel.
So if I was on
E:/Media/Games/Saves/Save 1
The panel on the left would still be on
E:/
Which I then have to open manually.
If I navigate to a different folder, I have to open the directory on the left manually as well.
It is annoying, and makes using explorer twice as complicated.
So if I was on
E:/
