I saw a windows 10 version. Is there a windows 11 version?Something to consider. If you want 11, get LTSC.
I've looked into all these "debloating" scripts. AtlasOS, winutil and winaero you name it. LTSC is basically a Microsft certified debloat without any risk of stuff breaking.
Yes, there is, link belowI saw a windows 10 version. Is there a windows 11 version?
Seems that it is based on 24h2 also, so pretty recent.Yes, there is, link below
Windows 11 IoT Enterprise LTSC
Windows 11 IoT Enterprise LTSC is intended for fixed-function, specialized, commercial devices that require a long support lifecycle of 10 years.www.microsoft.com
Except it's stuck at 22H2 soooo, no thanks. One debloat script for me, includes all my drivers, optimisations and apps (winget or choco) - takes about 30 mins to install and includes all MSFT baselines and CIS baselines. EasySomething to consider. If you want 11, get LTSC.
As the original question any advantage in the pro version?
thanks in advance
Hooray! No more wondering what AI garbage Microsoft will feature in the next update with proper policy to disable telemetry. If what you do works for you then great but LTSC imo is just install and forget.Except it's stuck at 22H2 soooo
It's irrelevant how many users are on the system. It's more about preventing lateral movement, untracked app behaviour, diagnostics, and other vulnerabilitiesIf I was the sole user, would I need that?
Thank you.Yes, there is, link below
No problem at all.Thank you.
