Evening ladies and gentlemen,
I have been having some very strange issues with BSOD at the moment on my Windows 7 Professional N x64 PC. It only seems to happen when its idle on the desktop and never when gaming. (Even though once I left it on the WoW title screen and it crashed.)
Downloaded BlueScreenView and the same filename has been coming up.
hal.dll+12a3b
ntoskrnl.exe+18c463
My system specs are:
i5-4670k @ Stock
16GB Corsair Vengeance @ 1600Mhz
Gigabyte GA-Z87MX-D3H (F3 BIOS)
Corsair H80
Fractel Design Core 1000
2TB Seagate Barracuda
DVD RW
CS650M
Gigabyte R9 280X OC WFORCE
What I have done so far:
Checked temps, Not too bad. Only concern is the HDD runs at 38-42*c.
Ran memtest86 4 times, only 1 error on first try.
Ran OCCT for a while on large data set, no problems.
Ran unigine valley and heaven, no issues.
Run Prime95 for 4 passes, all good.
Run Intel Burn test ( only for 5 mins), seems ok.
Ran HDTune error check, bluescreened every time I ran it until a few days ago.
Ran a Anti-Virus scan, all sorted.
Checked my c-drive for errors and fix bad sectors, all clear.
Added a side panel fan and turned the H80 speed from silent to medium.
Did a system restore back to a few days ago. Still waiting for results if it will BSOD.
And I am all out of ideas expect for updating the BIOS (which I don't really want to have to do) and removing the Molex to Sata converter for the H80 Power.
Thanks
JCX50
hal.dll+12a3b
ntoskrnl.exe+18c463
i5-4670k @ Stock
Corsair H80
DVD RW
CS650M
Thanks
JCX50
. Any Ideas?
