Grats Heffer23
The fix you found is a bit weird, but as long as it works its all good.
Just a gen add to your earlier querry.
If your router connects to a cable modem or settop box you essentialy take the cable from that device and connect it straight to your pc. Then turn the box/modem off, give it about 10 sec and turn it on again.
Seems a bit strange but Ive come across a few systems over the years that have had issues working via a router but connect fine via a direct connection to the modem.
