Yes, I know what the problem is
To use an upgrade version there must be an existing Windows install. The installer checks for this *before* the stage where you partition/ format your drives.
Easy way to get around this...
1. install win7 where you want it (create partitions yourself manually)
2. use a blank key when it asks (you enter "evaluation period" of 30 days).
3. reinstall win7 *without* formatting/ deleting your old win7 partition outside the installer.
4. format your partition with the win7 installer (by this time win7 installer has validated that you are performing an upgrade
5. use your upgrade product key
6. ???
7. profit.
[edit: you should be able to install to any partition using this method, but there are reports of some people having to install to the first partition on the disk; windows historically has always wanted to be installed to the first partition]
