Win7 XP Virtual Machine and Ubuntu
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Ello all,
Been absolutely ages since I've done anything remotely like this.
Im trying to create a new VM using the built in software in Win7.
I'ts seeing my ubuntu iso and starting the installation.
I have set the drive space available to the VM to 8Gb but whenever I get to the point of installation within the VM it says it needs a minimum of 4.8Gb space free.
The HDD is currently empty :/
Any ideas?
EDIT: If the ubuntu setup if I goto about this computer it says the HDD is 525.9MB
Virtualbox appears to have done the trick, installing now :)
Cheers brennan
Any problems with it just ask :) The community forum is very helpful too
https://forums.virtualbox.org/
Odd, I just fired up a Ubuntu VM and it worked off the bat. The only setting I altered was the guest RAM allocation. Are you using the 32bit desktop Ubuntu?
Yup 32bit 12.10 Desktop.
Interestingly when I tried to screenshot I got this:
And heres the VM info in case I've done anythign glaringly stupid:
Can't really see anything on the forum about it :(
Might just try a reinstall
The 8GB HDD is on my SSD with my windows install
i5 3570k
16Gb RAM
Sandisk Extreme SSD
6950 2GB
Yeah might try the 64bit one, initially I went with the 32bit one as all its for is to have a quick poke about
Tried them all this morning, gave it an extra CPU, more memory, more Vram.
Still the same, guess I'm reinstalling when I get in from work.
As you had problems with it in a different VM, and it's playing up in VBox, I'd try to dl the ISO again and check it's MD5
Crtl+Alt+T will invoke terminal btw
Yeah got to terminal and tried those commands in the vid you linked.
Will be DLing the ISO again (was direct from the ubuntu hoempage) when I get in from work
