Windowed mode games default to 1024x780?
Caporegime
8 Sep 2005
Norrbotten, Sweden.
This is weird - and is annoying just wondering whats going on.
Its a 22" dell monitor and a 4870 9.12 drivers. tho 9.11 did same.
Ever since i installed win 7 on release certain games want to run at this res, small res. When i set them up as optimal (MW2 for example)- Its like i have to force them to go to 1650 x 1050..
Also in everquest 2 Full screen runs at the correct larger rez but, windowed plays small until i have to force it again...
COH tales of valor did the same thing too. So im assuming its a windows 7 thing. Everything is set up in the OS correctly as far as i can see. Same in CCC its all set as it should be.
Any ideas? :confused:
when you set it to windowed mode it will reset the resolution to some arbitrary size that the game defaults too till you change it in options again i think they do it to stop you accidentally making a window so big you can't move it to find the edge/the change option button)
but usually once you change the ress to whatever in the ingame menu once it satays that way.
Least it does more me.
When i open supcom it always opens in a 1920x1200 window.
win 7.
It never used to tho, thats the annoying thing. Yes ive had plenty of times where i remember not being able to reach the min/max buttons in vista.
So this is normal then now - i dont like ! :(
tee hee
You know you could just click "windowed mode" before you set your resolution for the first time? :p \o/
