Windows 11 Installation Help
6 Jun 2018
Hi all,
I've just built a new PC but I'm struggling to get Windows installed on it.
I've tried various settings within the bios but either result in:
1. Inserting the USB device with windows which then causes my other USB devices to stop working
2. Managing to get into the boot options mode and selecting my USB device, which then brings to me to the main Windows installation screen of picking my language etc. but still disables my USB devices so I cannot select any options
I've made sure I've selected the correct options in the bios such as TPM etc.
At this point I hadn't installed my graphics card as I'm taking it from my previous build so I was using the integrated graphics, someone said that could cause issues so I installed my graphics card to still have the same issues.
I've changed settings for legacy USB devices etc. and also tried installing Windows 10, but it doesn't even get to the same screen (just brings up a blank screen).
Majority of tries result in a spinning wheel before the usb ports die.
I've also upgraded the BIOS to the latest version, amended XHCI, tried multiple usb pens.
I’m trying to use a Samsung 980 Pro if possible? Not sure if this is the issue as it was initially appearing as a nvme drive, then not at all until I moved it to another slot.
My motherboard is the B660-F, any help would be much appreciated, thanks!
You tried a different USB port?
Is the USB stick with the Windows install on it using a GPT partition?
Are you going into your UEFI BIOS and selecting the boot tab, then changing OS type to Other OS? (Or something like that as i tried to lookup the setting in your BIOS on the Asus product page but their manual sucks as it doesn't show any of the BIOS settings:()
Hi Murphy,
I’d need to double check the partition (means having to swap the graphics card back to my old machine). But both were done through the windows creator tool, although I may be best using rufus.
I attempted ‘other OS’ as well as ‘Windows’ but both didn’t work unfortunately.
My drive is now weirdly showing as RAID although no other devices are installed.
If you made it using the creator tool it should've created it as GPT so don't worry about checking that.
If your drives are showing up as RAID then you'll need to change that back to AHCI, like i said the Asus manual doesn't show BIOS settings so I'm a bit in the dark on where your specific BIOS settings is but you should find a setting under the advanced tab called something like SATA mode selection, change that to AHCI.
It maybe worth checking the USB stick works in another computer to rule out any faults with it.
Unfortunately I can’t see an option for that. The only option I find is to enable/disable the SATA controller.
I think there may be an issue with the motherboard as it takes a good 60 seconds to even let me get near the BIOS.
I disabled a setting (can’t remember which now!), but the drive is now showing as nvme, although still not as a boot drive, only option is the USB drive which just hangs when trying to load.
