So I've just installed a new mobo which required a fresh install of Windows. I can get a copy through work but foolishly I forgot to make sure it was the 64 bit version. So I installed windows and then realised it was 32 bit. I've already used the activation code for this. I've asked for the 64 bit version from work but they are taking ages to sort it out! Can I download a trial version of 64 bit and activate it with the same code or will it require the 64 bit code?
Cheers
Cheers
