Windows 7 5.1 sound problem
Permabanned
8 Dec 2008
East yorkshire near hull
Hey all i will try explain the problem the best way i can.
My seapkers are Logitech Z-5500 with windows 7 and i use optical to connet it to my pc.
The problem is the sound in the front left and right speakers. Basicly the sound coming from the speakers kinda sounds like they are rear speakers. You have to put your ear close to it to tell theres sound coming out. Compaired with my center speaker which seems to produce the most sound and the loudest sound.
Some times the right and left speaker will randomly start working like it should and then go back to quiet. When they do work you can really tell the differance.
They was working fine not so long ago, and they also work fine with my ps3.
I have checked my settings on my control panel on my speakers everything seems to be in order.
Any one got ideas to why this is happening?
