i'm new to windows 7 but v sync seems to be limiting my games to 30FPS it didn't do it on win xp pro
how do you go about correcting this
looked in cat AI and desktop everything is set to 60Hertz
I'im on win 7 64bit now. .
I choose 60rHz, but when i go back to it, it says 59.
have a check for us to see if it's still on 60.
Go to desktop, right click, click screen resolution/ then advanced settings, then monitor.
just see what it's on for me please mate, as i just want to see if it's just mine. but i've got around it now by using powerstrip.
as with 59hz, i would get very bad stutters in pro evo. with 60hz via powerstrip, it's smooth as silk. a lot of ppl say it dont matter, but in some games for me, it give me issues.
Anyway lol. what u have to do with your 30 cap issue, is download rivertuner,
http://downloads.guru3d.com/RivaTuner-v2.09-download-163.html
Install it as normal. once all done. click on start, (left hand bottom corner) click all programs, look for rivertuner, click on that, and other stuff will come up. look for D3Doverdrive.
click on that, then that will go stright to your tray on the bottom right hand corner. (should do) then click on that to open it up. then to get it to work in whatever game you are playing. look under Application profile properties, click the big ish + sign at the bottom left hand corner. then look for your games .exe.
I.E. mine will be. Local Disk (C) Program files(x86) pro evo, then pes2010. which will be my pes2010.exe. the .exe starts games up.
then you will back to where you started. make sure games .exe is highlighed. then choose application detection high, then force triple buffering on, then force vsync on.
just turn vsync off in your ati control panel. not sure if it really make any difference to be honest mate. but do it just incase.
it wont work if u don't choose your .ex thou.
Let me know how u get on
