I always have problems when it comes to reinstalling, it does my head in. Basically, I have a copy of windows 7 from MSDN through my uni. I downloaded it as a ISO file, so I burnt the image to disk using DAEMON Tools. The process of burning it seemed to work OK.
So I restarted my PC, set my BIOS to read the CD first which it did. Then when it came up with a screen saying windows is now loading files, it just stuck at that and bought up this error screen: http://dl.dropbox.com/u/11365869/DSC_0796-2-Edit.jpg The only things which were plugged into my PC were my keyboard and mouse, and my CD drive was fine seeing as it just burnt the disc.
I went back into windows and tried to reinstall from there. I bypassed the screenshot above however it now doesn't recognise the disc, basically saying it isnt a Windows 7 disc.
A friend told me to use imgburn as this had worked for him in the past, so I burnt another copy of the disc using this - but now it wont even burn properly. I get this error message just before it finishes the burning process. http://dl.dropbox.com/u/11365869/URGH.jpg
Sorry for the wall of text. This computer is really starting to annoy me..
Any ideas?
Any ideas?
Currently seems to be installing W7 fine!
