Windows CLI problem [HELP]
25 Nov 2005
I got a error message when I open the ATI Control.
Tried Uninstall the driver and reinstall the new one, but doesn't help.
Anyone here can help, thank you.
Can you re-create the error? If so i'd suggest you download "Filemon" from sysinternals.com
Run that program and re-create the error, it'll then give you an idea of what file/program that is causing the error. Then maybe find updates for it, or let us know.
Uninstall the .NET framework and then reinstall it. You'll find a link for it on the same page as the ATI driver download.
