- 26 May 2008
Hi all,
I run two monitors, Main monitor is connected by HDMI currently and is a 4k 160hz 27" display and was set as Primary, monitor 1 in my settings. The box is still ticked.
Second monitor is a 1080p 120hz display and was connected with a DP cable and set in Portrait, extended, monitor 2 in my settings.
Monitors were set like this for the past month, cables are this way simply because the 1080p had been connected to a different PC previous and needed DP to hit 120hz on it's older GPU.
Only today when I boot up, all my icons are on the left portrait monitor and despite the 4k being ticked as the main display, the main display is now number 2 the secondary portrait is now number 1. Nothing seems to revert this back to how it was previous unless I run the system as a single display on second screen only.
Has anyone else ever experienced this? Google simply has me go through the motions of ticking the primary display box. I have rebooted, tried swapping priorities, and nothing sets my main monitor back to display 1 with all the icons?
I will try unplugging the DP cable from the GPU. But this not being resolved at the desktop is bugging me.
