Wine for the novice.
I would recommend The World Atlas of Wine which shows each region, producers, their histories and gives a good background to wine with the influencing factors such as grape and terroir ( etc. It will also give you an idea of how to decant (not really needed for the majority of supermarket wines), what interesting points about the wine in the glass and above all - getting the right temperature for the wine.
It's well worth the asking price.
Right I have just drunk most of the Wolf Blass Cabernet Sauvignon "Yellow Label"
Now while it was OK to drink and it did get better the more I drank my overwhelming sensation is one of the wine being quite acidic.
Now is this a trait of whine or is it just me?
This change of character in red wine is called 'breathing'. Basically it's allowing the wine to get to the right temperature and also allowing subtle oxidisation to bring out additional characters. Whites aren't usually decanted.
Temperature really does play a large effect too on both red and white wine.
Decanting will bring this on and will also act to seperate any remaining sediment that will also affect the taste. Decanting is done in three steps - firstly, place the unopened bottle up right for couple of hours. Next open and *gently* pour the wine into the decanter whilst looking at the wine in bottle (a light shining through it helps to see any sediment) and the idea is to stop sediment in the bottle from getting into the decanter. So don't just up-end the bottle in as it will mix the sediment and muddy the taste (fine sediment takes a long time to settle). Then finally leave the decanter for an hour or two before pouring.
It's odd how a mere bottle of wine can change taste like this. It will continue to evolve in the glass.
Other causes of acidity are:
1. Grade variety - some varieties are acidic.
2. Crap wine - some wines are labeled 'acidic' but personally I think that's just an excuse in the common case (just my own opinon - I don't like acidic wine either).
3. Over oxidation ie leaving a 1/2 drunk bottle of wine in the bottle for 24 hours for example
4. Corking where the cork either fails to seal properly causing over oxidation or in the worst case the cork itself taints the wine (this really does taste bad). Take the bottle back for a replacement.
Ok, if you're feeling brave for a little experimentation:
1) Rioja - if you like a fruity wine then go for a Grand Reserva with either soley Tempranillo or a Tempranillo / Graciano blend. I love the older 1998s they come out really silky, mellow but bursting with berry flavour. Not a hint of acid! Expect ~£15/bottle.
Rioja have a classification system that is controled and enforced by their government so it can be trusted - look for the official "CONSEJO REGULADOR DE LA DENOMINACIÓN DE ORIGEN CALIFICADA RIOJA" label. it's easy to spot with it's tree..
Try this Pagos De Tahola Gran Reserva 1998 - which I'm just about to order myself a full case of too as the 1998 is getting sparse on the ground. Such a great year too!
Just remember Rioja comes from a warm region thus is usually served at a slightly higher room temperature.
2) St Emilion / Pomerol in Bordeaux. This is worth reading up on on the years and the producers.
In short - you can pay up to £4,000/bottle. Starting at ~12.. I'd personally look at £20-35.
St Emilion - although the wines will range from unclassified through to Class A Grand Cru Classe producers you can pick up Grand Cru bottles in the 20-35 bracket. Will usually blow the socks off any supermarket wine too.
Pomerol - sat next to St Emilion also a favourite. I loved the Croix du Casse bottle I had at a not ground shattering ~£35.
Next white - have a try at the following:
Off to New Zeland. Try the grape varieties Sauvignon Blanc or Chardonnay. NZ produces some of the the best Sauvignon Blanc.
A well known an respected producer is Cloudy Bay. Have a try of their wines. A CB Cardonnay is £20 at laithwaites for example.
My favourite is Chablis ("Shaab-lee"). In this region of france the houses are strict on their adherance to the Cru system. It's possible to pick up a reasonable vintage Chablis by the Grand Cru Valmur vineyard in the £20-30 that will leave a lasting impression that will beat the normal supermarket wines hands down. A non-acidic white.
It's a trait of that one. I had a bottle just after posting before and I found it quite acidic too. More of a wine to have with food than to drink by iself. I prefer my reds a bit sweeter and spicier than that one, don't let it put you off.
Might I recommend ChateauNeuf Du Pape. I didn't like Red wine till I tried this wine.
ChateauNeuf Du Pape is a village in France, and also an AOC, which is means that for wines to be labelled as a ChateauNeuf Du Pape they have to come from within a certain area. They also have a restriction on the grapes used to make them. The main grape is Grenache, which happens to be my favourite. I've had a few different ChateauNeuf Du Pape bottles and they've all been nice, but I'm quite happy with any Grenache Shiraz from anywhere in the world.
Again I'm no expert, but I have actually taken a wine tasters course and examination (and passed!). And I'm certainly pretentious, so feel free to ignore me ;).
A good wine is simply one that you enjoy. This can be a £3 1.5 litre bottle of French Red Table Wine from Tesco (a damned fine wine if I may say so), or a £3,000 bottle of Champagne. Indeed for me, the best wine I've had was a glass from 1920 Madeira that cost £900 (no I didn't buy it!), but my average spend on a bottle of wine is probably from the £4.99-£7.99 range at Cambridge Wine Merchants - then again they do let you sample some wines so you can decide whether you want the bottle or not.
I really do not like the major brands - (off the top of my head) Jacobs Creek, Ernst & Julio, Kumala, etc because of the way they throw in so many grape varieties to bulk out their vast production volumes.
Laphroaig on the other hand, is robust enough and the extra flavours from 30 years in sherry casks really adds to the experience and the 30yo Laphroaig is probably the best whisky I've tasted so far (bloody good job at £220 a bottle).
One of my absolute favourites. I got a 38 year old Talisker and a 36 year old Glenfiddich from my brother for Christmas, the Glen is bottle number 114 of 16,000. Man am I looking forward to drinking that ;).
True, very true.
Although I don't think I've tasted any wine at sub £7 that's not wanted to make me vomit unless it's accompanied by food to take the taste away or used in gravy! :D *gets wooden spoon out*
[DOD]Asprilla;10802027 said:
All excellent advice, the only thing I would add is that you can get NZ Hawkes bay whites for substantially less than Cloudy Bay. In my opinion they are mainly just as nice and some are superiour, but they don't have the same demand price premium as CB.
Very true!
I'll happily admit I've not really explored NZ or south american whites yet. Which is something I'm slowly looking at due to my now-ex gf and my lady housemate being white drinkers and being a mainly red drinker myself.
Yesterday I tried the Jacob's Creek Chardonnay Vintage 2006, 13% and I have to say it was better experience than the red wine I had previously.
There wasn't the sensation of acidity / burning alcohol sensation that I got with red wine I tried previously, that isn't me trying to compare red with white as such it is just me explaining the differences!
The Jacob's Creek Chardonnay was very smooth but I think I would like something a little more fruity if that makes sense, does anyone have any suggestions.
I have a Tesco grocery order to do so I am going to get a few bottles while I am at it!
Also are there any good wine websites for the novice to look at, nothing along the lines of Decanter as I found it a bit pretentious!
http://www.timesonline.co.uk/tol/life_and_style/food_and_drink/wine/
ETC
Sunday supplements of newspapers often have a few pages on wine too.
Best advice I can think of:
Go to a good off licence - Oddbins for example.
Ask them to pick you out 6 bottles of wine to whatever budget you feel happy with. Be honest about what sort of things you like - for example not liking "acidy" wine as you said above will help them find smoother wines that will maybe be more up your street.
The staff will then happily give you tasting notes for each. You can then drink each bottle and see what elements you like or don't like.
Well I have just cracked open a bottle of Gallo Chenin Blanc, which is pretty nice so I have something to work with at least now !!
Yup - bad reds can taste like vinegar!
Ok, how about a shift in white grape variety:
1) Riesling ("Reessling") - can be sweet or dry.
2) Gewurztraminer - fruity; often described "Lychees, roses"
3) Zinfandel - berries again.
Germany's Dr Loosen and France's Trimbach is a very well respected producer of Riesling but come over completely differently.
Dr Loosen 2004 is a fantastically fruity and slightly sweet, almost aperitif Riesling. The 2006 is not as nice - both myself and my house mate agreed on that. Expect 2004 at ~£12.
Trimbach Riesling is dry as a bone compared to the Dr Loosen but tasty none the less.
Sainsburys' own "Taste the difference" Gewurztraminer is a big fruity white and is my HM's favourite. Balanced (not too dry or sweet) but lots of flavour. A little acidic in my view but matches the fruity taste. ~£8
That's how I started.. once you find an interesting grape, region, producer and year then try other years, producers etc.
Parker, Decanter, etc are all prone to it.. I quite like laithwaites as the local one in Virginia Water has a good selection and the staff are quite open to allow you to try different wines.
I wouldn't label talking vintages etc as pretentious.. Looking down on people that don't know the difference or if a particular vintage was good/bad is... you can research that and it just shows how anally retentive they are.
In the end - as others have said, just try something and get a taste of each time of grape. Something like the Wine Atlas I recommended would aid you immensely as it has done with me.
Then perhaps research that grape a bit more - then try other producers and years.
I know I like Rioja from 1998 but I know the 1999, 2000 etc aren't as good for me as that year. Later years may be better but all the 6/7 bottles of 1998 I've had just hit the spot perfectly - so much so that I've ordered a case of 12 bottles of the stuff today!
I've narrowed the area of france I like, now I'll be looking at producers and vintages..
In the end it's all about what you like and part of the fun is finding that unexpected bottle that you remember!
