Kenai, you clearly want to stick to Sport contacts over the winter and are posting to justify your position (or whatever other summer tyre you use).
It is well known that winter tyres start to improve at -7, the manufacturers claim this and it would be retarded of them to make tyres that work under this temp when most of the time is spent above this, as it requires different compounds and silica content. But if you are unconvinced stick with what you have.
Why don't you show me some evidence that these tyres are better in ALL but snow when Evo clearly disagrees, and you have said nothing you havent already said before without countering points in my last post.
8th best in wet.... how is this best overall except snow?
What about ice?
What about damp salt slime where silica content makes a massive difference?
What about "white tarmac" with dry salt where silica content also makes a ig difference?
Flawed tests are flawed however you CHOOSE to interpret them.
Hey I will let your 6 years of driving experience counter my 28 years if you can actually provide something to counter the facts other than "your 7 degrees is invalid" when it is the benchmark every tyre manufacturer uses when designing winter tyre compounds.
What about ice?
