- 12 Aug 2003
- Dogsbodyville
SOLVED: WinXP fails to see second SATA drive
SHORT:
I have fitted a second SATA drive (non-RAID) to an existing P4C800, Win XP system, using the second SATA connector. The BIOS recognises the new drive, but when booting into Windows, there is no sign of the drive - in device manager, in 'Manage/Disk Management'. Nada, nowt, nothing. Do I have to do something in windows to force recognition of the drive?
Any other ideas
LONG:
Asus P4C800. WinXP SP2 + all patches. New drive is WDC WD2500K (250G SATA II).
In the BIOS,
the DVD drive appears as IDE Primary Master 1,
the existing Samsung SATA drive appear as IDE Master 3,
the new WD SATA II drive appears as IDE Master 4.
The new drive attributes, LBA, DMA etc, looks exactly as expected.
The BIOS boots from DVD then the Samsung. The option to boot from the new drive is not available.
The BIOS is set to non-RAID, Enhanced mode.
In device manager, there are no yellow '!'s.
Tried,
1. Booting from Linux installation disks. The new drive is presented as an option for installation/partitioning etc.
2. Booting from PartionMagic. The new drive is visible and partitionable.
3. Booting from the *original* XP installation disk. The new drive is presented as an option for the Windows installation, although, as expected, the drive size was limited to 128G.
4. Flashing BIOS to latest available.
5. Fitting jumper to new drive to limit interface speeds to SATA, not SATA II.
6. Swapped the new drive to the first SATA connector and the existing drive to the second SATA connector. Not suprisingly, WinXP fails to boot (boot.ini?)
7. Bashed head against nearest wall.
SHORT:
Any other ideas
LONG:
In the BIOS,
Tried,
