I've found the Bosch Aero twins to be absolutely terrible for the driver's side.
I love the idea... the whole blade bending rather than a static frame + bendy rubber... but they just don't work on this car.
I've tried both the 22" and 24" on the drivers side and both skip the middle bit (near the mounting point). The official size is 23" but they don't make them in that size, so they recommend either 22 or 24... tried both and they both do the same thing.
Ended up having to buy Halfrauds blades to get the car through MOT as nowhere in 50 miles had stock of the Bosch 20/23 combo and i needed them on a sunday for monday morning MOT.
The Halfrauds blades metal bashes against the metal of the stalk when they're used... LMAO. They're going back tomorrow...
Going to have to order and wait for the proper Bosch blades... the ones you just ordered.
EDIT:
Piccies... taken by wife in passenger seat while driving:
Wiper blade skips this section on its travel downwards:
Highlighted badly with laptop trackpad:
Different pic from different wipe, same thing:
Swapped them over from left to right too, in order to check it wasn't just a faulty blade or two... even the 20" blade that works perfectly fine on the passenger side does the same thing on the drivers side... there's nothing wrong with the spring in the lever. The 22" blade works fine on the passenger side.
