I need to do a re-install due to many progs going belly up...to avoid problems on re-install whats the best way of "killing" the drive so nothing remains as many progs manage to leave traces somewhere that last even though reformatting?
			Caged said:No program is going to leave traces which would interfere with a clean install if you just format the drive.
lolfallbayuk said:That quilted stuff works well.
Slime101 said:I can think of several...MS Office, Discreet 3DS MAX, etc etc. It needs to be properly cleaned...but how? (I know these progs leave traves even after fdisk and format from experience)
Lagz said:No. . .they dont (yes the data is technically still on the disk and recoverable by specialist software, but there is no way it can interfere with windows and new installs of the software).
AJUK said:A good old fashioned format c:\ from dos on a floppy booted pc will do fine, then just reinstall windows.
Indeed.dirtydog said:Or just boot off the Windows installation CD and let Windows setup do the formatting, even easier.
 Slime101 said:![]()
YES THEY DO!
Install 3ds max....remove it or leave it then reformat and try and re-install and see what it says, it WILL know you have installed before on that hard disk, i would bet my 20K landy on it...the program leaves traces that are not removed with a format or fdisk.
Slime101 said:![]()
YES THEY DO!
 You'll have to re-register or change your network card (which probably constitutes a breach of your licencing agreement)M0KUJ1N said:....And this wouldnt have anything to do with the fact that 3DS-max uses a network-based registration system (FlexLM IIRC) which is based on your computer's MAC address? No amounts of low-level formats are going to change that fact Im afraidYou'll have to re-register or change your network card (which probably constitutes a breach of your licencing agreement)
/me wonders what the shipping charges on a Land Rover are
Slime101 said:Stand alone installation - no remote registration required so how's that work then?
Whitewater said:There's either an active connection to the internet that the software's using to check the product code, MAC address, etc.
