Wired network help.
12 Sep 2006
I want to make a wired connection to my pc which is in another room.
I have purchaced 2 cat 6 walplates, one for each room.
Can i just run a cable through the walls and loft from1 plate to the other?
Also what cable do i need?
im a little confused as there seems to be a few, cat6 utp/ftp solid, stranded etc.
Any help would be most appreciated.
Is this the correct one?
Cat6 UTP Solid LSZH 4 Pair Cable Technical Data :
A 4 pair high performance cable that consists of 4 twisted pair solid conductors, used for data transmission. Cat6 supports a frequency range of 250Mhz and is designed for speed of up to 1 gigabit per second.
Standards : ISO/IEC11801, TIA/EIA 568B
Conductor : Class 1 Solid Plain Copper 24 AWG
Insulation : HDPE (High Density Polyethylene)
Sheath : LSZH (Low Smoke Zero Halogen)
Sheath Colour : Violet
Temperature Rating : 70ºC
Core Identification : Blue + White/Blue
Orange + White/Orange
Green + White/Green
Brown + White/Brown
Sounds good to me!
Do you have a IDC Punchdown tool for the faceplates? Makes it a helluva lot easier. Can be had for a few quid from auction sites.
