Wired USB C earbud recommendations?
22 Jul 2012
UK
I'm looking for some wired USB C earbuds for £20ish.
Will mainly be used for listening to music or radio streaming when I'm on train journeys. I prefer wired compared to Bluetooth.
Would strongly recommend considering cheap-ish IEMs and whatever 3.5 - USB suits your phone. Will open options a lot. MAYBE a little fund creepage (but only say... £30).
The Tangzu Wan'er can be had for £13 + postage at the minute, not the cutest looking but will utterly destroy anything else (except other well priced "chi-fi") remotely in the price range on sound quality, the cables usually about £3 and postage... maybe IS doable in £20.
Cheers, I'll check those out.
The DAC sits within the earbuds when using USB, so not a massive amount of good quality within budget, but the JBL Tune 310C are pretty decent and well within your budget.
This + a dongle or the Chu 2.
The wan'er is better sounding though, the Chu 2 is more V shaped than I liked. But Chu 2 is better built though, all metal.
