Hello? 1983 is callingRhys said:if a wii can then surely they can make lightguns. I just want a lightgun game.
what about lcd monitors?XPE said:I dont think they are possible on an HDTV.
They can easily be calibrated to do so.SiD the Turtle said:Hello? 1983 is calling
As I understand it (I don't have a Wii) it doesn't work as a light gun per-se, a two inch hand movement to the left doesn't translate as the same on screen.
ElRazur said:Why is that?...You mean RPTV?
Jono said:My dreamcast lightgun wouldn't work on the downstairs widescreen telly (crt) properly, worked great on the 4:3 one upstairs. Anyone know why it wouldn't work on widescreen at all ?
HotD2 btw.
