Wireless Booster/Router Advice
7 Apr 2004
Hey guys,
I currently have a Netgear WG602 Access Point at 54Mbps (using WPA-PSK), and want to extend its range, could someone recommend some equipment that will do this im not sure if i need another access point and what it needs to support etc, but it needs to work with the current wireless setup, stronger the signal range the better.
Thanks a lot,
Jack
Get another one of the same version and set up repeater mode. Made sure you're running the latest firmware so you can run WPA encryption
