Wireless charger?
17 Aug 2009
Finchley, London
I've never had a wireless charger but am I right that a wireless is slower than wired? Does anyone know if I can get a wireless charger to match the fast charging of my wired Samsung adaptive charger for my old S21FE?
Generally much much slower especially compared to any form of wired fast charger, it also generates a lot more heat and therefore isn't great for your battery if that's something that bothers you.
Yea it's a trade off between that and wearing your charging port out if you are intending to keep your phone long term.
I use a bit of both now, I use a wireless charger whilst I'm working and tend to use a wired fast charger more over the weekends and for a fast top up if I need it.
My old phone the charging port wore out before the battery, although I managed to replace that and the battery, it's still going today, I use it for work probably be about 8 years old.
Thanks guys. Yeah, I think my charging port is wearing out. At home, it still fast charges but quite often the first time I plug the cable in it'll say slow charging and then when I reconnect it'll be fast charging. In the car, I've got two fast chargers that push into the 12v lighter socket, both of which used to fast charge but now only slow charge. My feeling is it's probably to do with the charging port. So I guess I'd best buy a wireless charger at least for home in case the port completely packs up. I saw a 10w Belkin wireless charger at Currys for £14.99 and a 15w Belkin wireless charger for £24.99. I guess I should get the 15w. Is £24.99 too much? Oh and some other brand in Currys, 15w for £19.99.
I used the official 50W wireless charger with my Xiaomi 14 for a while, but found that the temperature stayed elevated all night even once the battery had reached 100%.
I stopped using it and returned to wired charging.
Now with my Oppo Find N5 I've only ever tested wireless charging works, have not used it since!
I went back to 10W, 15W got too toasty for my liking and it even eventually fried out the wireless charging on my old Pixel 6 Pro. Definitely slower but the temps are more reasonable.
Well a 10W charger is only £14.99 so that's ok. To charge from zero to 100% on my S21 is in the region of an hour and a half or so. Roughly how long would 10W take?
Varies depending on the phone's idle drain and battery size. Assuming it's the standard S21 I'm going to guess ~2 hours, maybe more.
Quick Google says the max wired charge rate is 25w so you're looking at well over twice as long to wireless charge
Thanks guys, yeah, probably closer to 3 hours which is pretty much equivalent to wired slow charging.
are all wireless chargers supposed to be the same? the only one I have is on my Ebike.
I tried my toothbrush on it and my watch but none of them charge, they act like its not enough watts or so.
you can get USB C cables that support 240watts btw for charging laptops etc, most phones probably support like 30-100watts fast charge.
Generally no, a lot of products have their own specific wireless charging setups.
Phone charging is slowly becoming a bit more standardised with Qi standards though.
As mentioned Qi is the standard pretty much all phones support. Some watches do support it but not all of them, a family member's Galaxy watch 6 works with it, my older Galaxy watch 3 didn't. Toothbrushes uses their own thing. Earbud cases also usually support Qi.
Yes, wireless charger has saved me many times, when i could not charge my phone with a cable.
Do the decent chargers still have little fans.
I asked about these chargers a year or 2 ago. People were saying the higher watt chargers had little fans and I couldn't be doing with the noise if it's next to my head in bed
The Samsung Duo charger has a fan & it's genuinely whisper quiet
Same here. It's clearly not the best method in terms of performance, thermals, longevity etc but the practicality of being able to put my phone on the charger with one hand in less than five seconds makes a big difference for me.
I spent a lot of time carrying kids at home and it's just not practical to put them down, grab the cable and plug a phone in... I frequently had the battery nearly drained before I switched over to mainly wireless.
