- 21 May 2003
Hi. I'm using Windwos xp with a kcorp wirelss pci card to a netgear adsl/router.
IF I leave Azureas runnning over night, the wireless connection will crash, guaranteed, in about 2-3 hours. It's a very wierd crash, windows says it's connected and ipconfig is all good. juts nothign can connect to the internet. if i try to disable the connection then windows crashes.
Even wierder thing is at home using a dlink router everything worked fine for days.
It's not just with azureus, I tried downloading a video with opera last night and the same thing happened.
ANyone know wy the netgear router causes this or if it's the router's fault?
