I am really fed up with the wires on headphones. I have been looking at these http://www.overclockers.co.uk/showproduct.php?prodid=SP-094-LG&groupid=702&catid=1058&subcat=1847.
I am worried though that these type actually bypass the soundcard i have invested in. Do they bypass the soundcard? If they do can you suggest a set that dont bypass the soundcard? Or what are the best ones available that have a built in soundcard?
the base station plugs in to your soundcard using a normal jack and the range on them is good
