Hi all,
My notebook PC has an Atheros AR5005G wireless chipset in it, but I can't find how to enable it!
I'm running XP Home, and I have installed the Atheros Config Utility. I can't find how to enable the wireless NIC either in Windows Zero Config or in the Atheros own software.
The connection exists in Network Connections, but is "Not Connected".
Obviously when I scan for available networks, nothing is displayed.
When I run the Atheros diagnostics, it says that the radio function is turned off.......
and of course I already know that!
I know the wireless LAN is working cos there are other PCs on it. And the PC's wired LAN port works fine.
Anyone have any ideas?
Thanks,
Irf.
and of course I already know that!I know the wireless LAN is working cos there are other PCs on it. And the PC's wired LAN port works fine.
Thanks,
Irf.
