So you want a step by step guide to setting up a router, whose make and model number you didn't even post?
If you just hook it up the network parts of it should work fine, but the ADSL side will need some configuration. As I've said, you'd need to give a make and model to go much further than that...
As said, if you don't help us to help you, you aren't going to get far.
