- 12 May 2004
- England
Foscam FI8905W 60 LED Wireless IP Camera @ £66.90
that any good?
that any good?
Specifications
Image Sensor 1/4" Color CMOS Sensor
Display Resolution 640 x 480 Pixels (300k Pixels)
Lens f: 8 mm F:1.2 (IR Lens)
Min. Illumination 0.5 Lux
Lens Type Glass Lens
Viewing Angle 40°
Image Compression Format M-JPEG
Image Frame Rate 15 fps (VGA), 30 fps (QVGA)
Image Resolution VGA (640 x 480) / QVGA (320 x 240)
Flip Mirror Images Vertical / Horizontal
Light Frequency 50 Hz, 60 Hz or Outdoor
Video Parameters Brightness, Contrast
Ethernet One 10/100 Mbps RJ-45
Supported Protocol HTTP, FTP, TCP/IP, UDP, SMTP, DHCP, PPPoE, DDNS, UPnP, GPRS
Wireless Standard IEEE 802.11b/g
Data Rate 802.11b: 11 Mbps (Max.), 802.11g: 54 Mbps (Max.)
Wireless Security 64/128-bit WEP Encryption
Infrared Light 60 IR LEDs, Night Visibility up to 20 m
Working Condition 0 ~ 55 °C (32 ~ 131°F), 20 ~ 85% R.H.
Storage Temperature -10 ~ 60°C (14 ~ 140°F)
Storage Humidity 0 ~ 90 % non-condensing
Power Adapter AC 220 V ~ 110 V / DC 5V 2A (US / EU / UK / AU plug)
Power Consumption 5 W (Max)
Figure Size 180 (L) x 98 (W) x 103 (H) mm (7.09 x 3.86 x 4.06 inch)
Certification CE, FCC
Weight 953 g (33.6 oz)
One Set Included
1 x Wireless 60 LED IP Security Camera
1 x Wi-Fi Antenna
1 x Mounting Bracket
1 x Network Cable
1 x Power Adapter (US / EU / UK / AU plug)
1 x Software CD
1 x User Manual
Standard Factory Package
