- 6 Feb 2018
Hi,
I started approaching to VR & AR, and I was wondering what are the current wireless technologies available. As far as I can see, both Oculus (with Oculus Go) and HTC seems to have developed some wireless product low budget (more or less).
My question is: ok for the low-cost, but there is non-low-budget tech available that does the same thing?
If I want to try to map a room, ora a house with a 3d environment (so if the user touch a wall, there's a wall), there are technologies if you have enough budget?
In theory what you will need for this kind of project is something wireless with position tracking (even better with gesture tracking).
What is the best existing technology to do that? It's ok even if is one high-budget tech, it's just to understand what's available![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thanks guys![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Francesco
Thanks guys
Francesco
