wireless mouse falling asleep
2 Aug 2010
Straya but now east London innit
After the last windows 11 update my wireless mouse keeps on falling asleep and it is driving me nuts. I have looked in every place I can think for USB powersaving and turned it off but it keeps on doing it plus I originally thought it was the mouse so I replaced it but same thing.
Any other ideas?
What mouse is it?
Do you have proprietary software installed for it?
Did you setup a profile for it, that you've tweaked to your settings - i.e. button layout/RGB etc; as that might have a 'turn off after X' that you've missed?
Its just a cheapie Acer mouse, will see if there are drivers for it. This is a replacement mouse as the old one was doing the same thing after a latest update.
OK, maybe Windows update, removed a working driver, and replaced it with a generic one/crap new driver with a silly feature the predecessor didnt have?
Any other ideas?
Open Device Manager and go to the usb (bottom) and check in properties that the "turn mouse off to save power" is NOT checked; then check your power settings, reboot pc.
