Wireless mouse - interference?
20 Jun 2005
London..
Wasn't quite sure where to put this post so here goes:
I have a Logitech MX620 cordless wireless mouse and it's causing some interference problems...In the same room I have a wireless TV receiver receiving a transmission from another room(sender attached to cable box), it works fine but the only problem is when I use my mouse in any way it causes massive interference with the TV...
So I was wondering, is there any way I can switch the frequency that the MX620 uses? Will this stop interference?
Thanks
Most wireless products do have at least 2 channels, for this very reason, Im sure if you check out logitechs site, it will illuminate you, if you cant find anything your TV reciver probably has alternate channel frequency too, so check their site
