Hi, been trying to install wireless for 3 days now and it is beggining to get me down
I have the Netgear 311T card + the WG624 router. I got the router installed OK and set up WPA-PSK.
I had problems with the Netgear card software, so had no option other than to use the windows zero config utility. This seemed to work OK because I get the wireless network up and running.
But ... I can't connect to IE via wireless. I can connect fine by just plugging the NTL modem into my box, just not via wireless.
I've disabled the windows firewall (no software firewall installed).
This is driving me crazy ... can anyone help?
