hey guys,
I'm having some trouble with my wireless setup at home.
I currently have a netgear DGN2000 router a laptop a HTPC (also wireless) and a smart phone.
My problem is that I can't connect both the laptop and the HTPC wirelessly to my router at the same time as they seam to cancel each other out.
If I use either one or the other I have no troubles, which makes me think they are interfering. They are all in the same room (my front room downstairs) so signal strength isn't an issue.
I have tried changing the channel number on the router but this has made little difference.
Is there any thing I can do so I can have them both connected at the same time??
Cheers in advance!
Cheers in advance!
