My g/f has brought her first wireless router and a wireless usb adapter(plugged into pc)
They are both netgear
Router is a Rangemax. Model DG834PN
USB Adapter is also a Rangemax. Model WPN111
The problem is it is only running at half the speed when it is supposed to run at 108mbps, where as ity is only running at 54mbps.
Can any one give any guidance as to how to get the speed up to its full potential.
(oh at the moment, both router and adapter are in the same room as she was testing them out, the computer will be moved later on)
Also she has a laptop with onboard Wireless and has some problems with MSN messenger disconnecting itself and the same with games. any assistance would be gratefully apreciated
Sic6siX
Sic6siX
I can't explain it any clearer. What does it say under the Wireless Settings section of the web management?
