Wireless Print Thingy
Permabanned
22 Apr 2007
Hi all,
Is there a simple device (USB Stick style) where one plugs in to the computer and the other plugs into the USB port on the printer so I can print wirelessly?
Ta
there was once but it wasn't exactly simple. You had to have a powered adapter in the printer. Think it was discontinued.
There is the wireless usb standard which is now becoming available which is kind of a hub and usb dongle.
Belkin do a network to usb hub/tool and there are numerous wifi print adapters which could do what you're after.
You would need a wirless print server and then you clould connect to that by makinh your computer wireless using a wireless card.
