wireless printer
Guv
Guv
24 Oct 2002
Warwickshire
Can anyone recommend a wireless printer?
I'd like an all-in-one (print/copy/scan).
I prefer Epson as the ink always seems much cheaper than, for example, HP. Another make with cheap ink is fine though.
Thanks
Hi Guv,
Cant recommend an inkjet, but I have the Samsung SCX-4500W laser mutlifunction printer.
Excellent software, fairly easy to set up. Copy and scan functions reprosuce very good results and being laser fast printing. If left on standby it will turn on and printout when needed.
Do you need the printer for any particular purpose or just looking for a good all rounder?
Hi
Thanks for the recommendation. I'd like a colour printer so I guess that means inkjet only as I'm not looking to spend loads on a printer.
Looking for a good all rounder. It'll be mainly used for printing documents, colour images etc. Images don't need to be amazing quality so don't need a professional photo printer.
