Wireless range booster help
5 Dec 2008
Peterborough
Hello guys, need some help, I moved in to my new house, I originally wanted to go with Virgin media Fibre but they cancelled the move saying they wont dig over 10 meters even though next door have it. So I have BT Infinity which is great 38mb down, and 9mb up and 15 ping. But I am using my Dlink DIR-655 instead of the home hub. But the range wont cover some parts of the house due to size of house and thick walls, any recommendation on a access point to go with this router. And also is anyway to use the Home Hub as a access point?
Cheers for the reply, its one bedroom, and a large living room, I just need wireless in the rooms, as the Master socket was put in the Study as I didnt want wires across the house. Im not sure which access point to use, is it better to use the same brand as the router I have?
