I have been doing a bit of browsing and discovered that the type of wireless security that i use WEP is basically useless, there are programmes that you can download and run and voila in 60s flat you are into a 128Bit encrypted wireless network.
I know there is also WPA and WPA2, are these the same? good? What is the difference between the three?
Are there any other types you can use?
Cheers.
Cheers.
). All this to ensure no-one can interfere with my using gmail and OCUK
