Wireless Trouble
25 Mar 2007
When I'm gaming....every 40 seconds I get "Connection Interrupt" for about....5 seconds and I've tried everything to try and fix it.
I have BTYahoo wireless internet and my main hub is downstairs and my computer is upstairs where I have a wireless adaptor plugged into my computer.
Is there anything I can do like, buy a cable or something to stop this? Does overclockers sell something for this? :(
please help
whats the wireless signal like? its probably quite weak causing it to have connection issues.
you can buy a cat5 crossover cable (google it) and run it from the hub to you pc upstairs.
my signal (when I don't have the connection interrupt) is either 4/5 or 5/5 so pretty good. I will take into account your suggestion, thankyou
This is what my friend wrote to me on a forum:
you might often get a few crashes with cat5 crossover cables unless the other PC is barely used at all, i would recommend getting a switch if at all possible!! This way it works as a router but priorities and orders the packets so that you get no crashes
I don't quite understand what he's going on about when he says I need a switch. What takes less hassle if my PC is upstairs and my hub is downstairs?
I wouldn't trust what he says, because that's a load of drivel.
From experience, the wireless on the HH seems to randomly drop out. Closest to a fix I ever found was replace it.
Lynch said:
so would a cat5 crossover cable be a waste of time?
If only the wireless is dropping out, no. If the router's entirely crapping out, you aren't gaining anything.
would it be much better to just replace the hub instead?
If you want wireless or it's completely breaking, yeah. I'd be inclined to swap it out anyway.
