- 31 Oct 2012
Evening all,
My HTPC is located in one room, my wireless router in another.
I'm using a Netgear Wireless N USB dongle (this one http://support.netgear.com/product/WNDA3100v2) and the signal is appalling (I get 2 out of the 5 bars, never any more).
I'd like ideally to connect the two physically but there's no actual way I can do this without running a cable all the way up into the loft, and all the way back down again. As I live in rented accommodation, this isn't possible.
I've played with the dongle and it's settings, I just can't get it to go any quicker. One of those things I guess. Wireless, meh.
So, I was looking into those devices that you plug into the wall to use the house circuitry. Does anyone have any experience with using these? If so, what model are you using and what's it like? Any particular brands that I should look into or avoid?
Thanks for your help in advance.
Cheers
David
Cheers
David
