Hello,
This is the headunit manual in question; http://www33.jvckenwood.com/pdfs/B5A-0816-00.pdf
I'm ready to install, however i'm not sure if the headunit has a remote turn on wire, the manual lists a "power control" 12v wire. a google search hasn't resolved my question. I would just cut it, but as the wire goes into the iso block and seems to connect to another wire in the original iso block i'm uncertain. regards.
fyi the wire in question is blue with a white strip, which gives me some confidence it's a remote turn on wire.
