Hey i have a problem which could do with some help.
Trying to put in a new light, but didnt think to look at the wiring of the old light when i took it off.
Light has L,N,G all good so far. Place i fitting new light has 6 (yes 6) wires from what i can tell 2xL, 2xN, 2xG. 3 of thesei think are comming from the switch, and 3 carry on i presume in a loop maby to ring as there is no other switches for this light.
So i wired it up with all the wires going into the corresponding holes (2 into each of the 3 places on the light) poped the fuse back in and they looked great, turned the switch off and the fuse blew.
Dose anyone know why this would be? or how it should be wired to make it not blow when i turn the light off?
cheers
cheers
cus i felt like a **** in my last post
