- 24 Feb 2004
- Leeds/Cyprus
While I was browsing Logitech's Support FAQs looking for a solution to my other mouse problem I inadvertedly came upon a solution to another problem I had occassionally been having: a wobbly mouse pointer.
Now, I only get this very rarely so I never bothered finding a fix for it, but since I stumbled across it I thought I'd follow the link to the Microsoft KnowledgeBase article they linked to and apply the solution described there. However, when I followed its instructions and opened the mouse properties applet from Control Panel, I didn't find an "Enhance Pointer Precision" option anywhere in there! It was neither under the "Pointer Options" tab (which is just called "Pointer" in mine) as the KB article says, nor under "Motion" as XP's offline Help says.
After a while the penny dropped and I realised the reason I can't find it is because I'm not using XP's mouse control applet at all - I'm using Logitech's Mouseware! Unfortunately, it seems to have replaced the built-in Windows applet at all levels (even typing "control mouse" from the command prompt brings up Mouseware), so I don't know how to get to the XP version!
Any ideas?
Any ideas?
