Hi Guys
I have just installed E8500 and have been checking my settings, my temps seem high I am getting 50c to 54c at desktop and 60c under load are these not high I thought this range of Cpu's ran cooler. I had a E6850 before and that ran lots cooler than this. Spec of my Pc is below
Also I have just completed 3D Mark 06 and scored 11,944 is this result ok, the Cpu is running at the stock speed have not tried to OC it yet.
http://service.futuremark.com/results/showSingleResult.action?resultId=5389174&resultType=14
PC Spec
Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB)
Zalman CNPS9700-LED CPU Cooler
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
OCZ 4GB (4 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 x Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache RAID 0
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Creative Sound Blaster X-Fi Platinum Fatal1ty 7.1
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Antec P180 Advanced Super Midi Tower Case
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Razer Tarantula Advanced Gaming Keyboard
Razer Diamondback
Creative Fatal1ty Gaming Headset
Vista Ultimate 64bit
2 x Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
3 x Antec 120mm Silent case Fans
Netgear DG834N 270Mbps RangeMax NEXT Wireless ADSL2+ Modem/Router
Netgear GS605 5-Port Gigabit Desktop Switch
PC Spec
Razer Diamondback
those temps are reading high, same cooler as mine and idle at 30c after warming up in winodws and not much higher under load. Just check your seating and I presume your case is tidy and adequatly cooled. Recheck with core temp and asus probe, both give similar readings but plenty of info out there about temps not acuratly reported though so just a rough reading for now.
