Hi all.
I recently won a Gigabyte R9 290X (I know, how lucky!?) and I need to build a budget system around it.
My current system is Shuttle SX58J3 with an i7 950 (socket 1136), Radeon 7850 2gb, 8GB RAM and HDD.
I'll move the HDD and RAM to the new setup and I was thinking of getting the following...
i5 Haswell 4570 socket 1150
ASUS B85M-E socket 1150 mATX motherboard
Aerocool Dead Silence case
Coolermaster GM series 650W PSU
Now I know you're all going to start screaming at me to get a K chip but I'm already at the peak of my budget. I want a mATX case because I live in a small apartment and that motherboard is cheap and has PCI-E 3.0 and enough front USB 3.0 ports that I need.
I'm concerned that the 650W PSU may not be enough but I've heard as long as I have at least 600W and not overclocking, then I should be able to power the R9 290X and the rest of the system.
I also know you'll scream at me to get a SSD and I certainly will but not just yet (I'm very limited by my budget).
Does anyone think my build list is sufficient? I'm not trying to create a beast, just trying to get a good build from my budget which is already over what I had hoped.
Think I know where you won it
