Wood accent case options
According to the Antec site only the Pro comes with the tranquil fans and the reverse fans are the P12R instead of just "reverse fan" (and the pro comes with 2)
Another difference I've just noticed is the Flux Pro doesn't have tray cutouts for reverse connector motherboards whereas the Flux and SE do.
I picked up the: Antec Flux Mid Tower Case - Black
In Jan for a new build, its a really nice and thought out case, everything was easy to understand and use. Extra fan below the gpu is an interesting place, but I stuck another exit fan on top at the rear.
Honestly, its gorgeous to look at and I am so anti RGB, so seeing the mobo power button and a GPU light makes it feel sleek and hidden rather than in your face.
Got my Flux SE delivered today. Can't move from my old case just yet but it looks nice and roomy and I can finally use a 360mm AiO instead of my current 240.
Swapped my machine over from an NZXT H5 Flow to the Flux SE.
Really liking the Flux, it's not got as much extra space as I thought it would over the H5 but building in it is so easy, it really does just come apart so you can get access everywhere!
I've been at it for 3hrs so stopping now, It's up and running but needs cable managed and as I've swapped out fans and the AiO I'll need to set speed in the BIOS, the fan hub wasn't showing in HWinfo but the fans were spinning so again I'll figure that out another day.
Hmmm, I can't say I'm impressed with the included fans, I'm using the reverse GPU fan and the 140mm outake (got Arctic P14s as intakes) and even at low (<600rpm) I can hear a droning noise from them, they'll have to be lowered in speed until I can get them swapped out. Might just buy some more P14s.
@Ace Modder are the fans with the SE & non Pro THAT different from the Pro ones? I'd have hoped the SE would have quiet ones considering the acoustic pads and target audience?
Really enjoying reading all the love for the C8 and FLUX model from us (Antec).
Any questions you have regarding Antec products, I'm here to help.
^ Why no quiet fans with the SE? I get the Pro is more expensive so you have a bit of extra budget to play with but I'm unimpressed with the stock ones on the SE so much that I'm buying seperate fans to replace them :/
It's a quiet case, add £10/£15 and include 140mm instead of 120s :)
The Flux Pro is fantastic. I can't fault it, very quiet case, great temps. Looks classic, with some subtle RGB through glass side panel. Great balance between black box and fish tank overkill.
