WoooHooo Extension Tubes!
26 Aug 2003
The North
My kenko extension tubes arrived this morning and just had time to have a quick play inbetween work. So excited I thought I'd share them with you guys :)
So far soo good, although you have to be amazingly close to get in focus...
All of these are uncropped too!
I dont have a problem with spiders at all, I always rescue the mrs from them, but looking at that first image bothers me a lot.
Great work :)
:) Cheers!
My work doesnt involve spiders! They are just some random ones in the garden. Quite worrying when you see what they look like close up!
The setup was, all 3 kenko tubes and my 100mm f2.8 macro lens on the 350d.
yak.h'cir said:
:) Cheers!
Ringflash?
You've done a great job with focus and depth of field.
I have the same setup and it does make for some interesting macro opportunities :)
Some of my shots here
I'm very interested in getting these kenko extension tubes but I need to know few things.
Can you attach these to any lense e.g prime/zoom/telephoto?
If I was to attach it to e.g 50mm 1.8, will it give me decent result?
This looks like a great lens, and at a pretty good price too! Great job with the pics, the first and last are definately my favourites.
Fstop11 said:
Very good. I regret selling my extention tubes now.
Why on earth would you sell them?!?!
danza said:
Ringflash?
Nope. I used a sigma 500 super flash on a cord. Works ok, but would love a ring flash sooo much!
Thank you! Have you tried the tubes with any other lenses? I'm looking forward to trying it with my 70-200mm f4 to see what happens. :)
You can use them with a 50mm 1.8. A 50mm is prob the best lens you can use with them. You will get excellent results with them!!
Its just your quality of your lens... at a much closer focusing distance..
A good cheap option
Coz silly me didnt think Id want to go much closer than 1:1
Thank you!
The picture SDK posted has been playing on my mind! Now I really want a ring flash!!!!!!!! Would be sooo nice not to have to worry about the tripod/holding a the flash i have close to the end of the lens etc, its a heavy set up for one hand! Not to mention trying to keep steady and in focus at the same time!!!
Hmmmm.... ring flash....
A good cheap option
oooh, so if i get the 50mm 1.8 which is around 70 quid i think, and one of these thingymabob's:
Teleplus DG 2x MC7 Convertor
Ive affectly got a 100mm lens which is just as good, while saving around £100? (bar the macro feature of course)
